Fixture Creator Help
So far these tutorials have been created for the Fixture Creator
First of all you need to learn how your Fixture works.
This can be done by the PDF/manual or Just to play with your Fixture.
Now if you know how your Fixture works you can Create you Fixture file.
Some basic info
For Movingheads Follow these Tutorials.
For Ledpars Follow these Tutorials.
For Parcans/Dimmer/Switchpacks Follow these Tutorials.
For Fog machines Follow these Tutorials.
For more complex fixtures that are controled by more fixturs in combination.
For parameter / functions that can be used in Fixture Creator
Others
Tutorials that requires that reader is familiar with the Fixture Creator basics.
Some fixtures don't fit any of the standard controls and in such case a bit of creativity are needed.
The fixtures bellow have a bit of this creativity.
More Tutorials will follow.
And for more info about Fixture creator look at this page:
