Output Menu
Lock Output
This function freeze the output from FreeStyler.
All fixtures will get a red box and in the menu bar a padlock is shown (Right side).
To unlock click “Lock Output” again.
Show Output
This window monitor the actual output value on the channels.
If a channel has been manipulated then the text will be shown as white on a red background.
The manipulation can be patching to an other channel or a correction offset.
See: Patch and Correction
By right clicking on a channel the popup menu bellow appears.
Invert Channel
This function inverts the output.
Normal the fader from 0 to 100 % gives the DMX value 0 to 255. Inverted the fader 0 to 100 % giver the DMX values 255 to 0.
Disable Channel
Disable the single channel so the value for this channel will not change but continue having the value from the time where it was disabled.
Remove Channel from playback
!!!!!!!!! Please fill-in info !!!!!!!!!!!!
Reset channel settings
Remove lowest, highest limit, invert, disable, patching and correction for the single channel.
Reset all channel settings
Same as above but for all channel.
Set as lowest limit
Is set by moving the control for this channel to a given value and then “Set as lowest limit”
The value from the control can not go lower than this value.
It is reset by Reset channel settings.
Set as highest limit
Same as above but just for highest limit.
Remove limits
!!!!!!!!! Please fill-in info. !!!!!!!!!!
