fixture_creator:tutorial:led_parcan:arc2_s
ARC2 + S
Enter manufacture name “Chauvet”, Fixture name “ColoradoZoomW 6ch” and Select the fixture picture.
Enter then Total Channel. Here in this mode it is 6.
Check “on” RGB.
Additional the fixture has a white channel.
Fixture Creator has two white channel contols W1 and W2. Here W1 is chosen. There is no difference if the one or the other are used.
In this mode an intensity channel is also available this is entered in the Lamp control. And to make a shutter function the intensity channel is also added to Shutter channel where full intensity, DMX value 255, correspond to “Open” and DMX value 0 correspond to “Closed”
The ARC2 + S mode also have a strobe mode. Fixtures with lamps in normally have a mechanical shutter and this is also used to make the strobe effect. In LED fixtures this is not the case and where a strobe normally is turned off by leaving the shutter open or closed, then this LED fixture has an off value on the shutter channel.
The strobe channel is here 6 and it is flashing with values from 10 to 255.
Fixture Creator - Lamp Configuration
In FreeStyler the will be a lamp and color control panel.
Link to Panel Description - Lamp Panel
fixture_creator/tutorial/led_parcan/arc2_s.1320528127.txt.gz · Last modified: (external edit)
