fixture_creator:tutorial:led_parcan:arc2_d
ARC2 + D
Enter manufacture name “Chauvet”, Fixture name “ColoradoZoomW 5ch” and Select the fixture picture.
Enter then Total Channel. Here in this mode it is 5.
Check “on” RGB.
Additional the fixture has a white channel.
Fixture Creator has two white channel contols W1 and W2. Here W1 is chosen. There is no difference if the one or the other are used.
In this mode an intensity channel is also available this is entered in the Lamp control. And to make a shutter function the intensity channel is also added to Shutter channel where full intensity, DMX value 255, correspond to “Open” and DMX value 0 correspond to “Closed”
Fixture Creator - Lamp Configuration
http://www.freestylersupport.com/wiki/extrafiles/Chauvet_ColoradoZoomW_5ch.pff
In FreeStyler the will be a lamp and color control panel.
Link to Panel Description - Lamp Panel
fixture_creator/tutorial/led_parcan/arc2_d.1324474377.txt.gz · Last modified: (external edit)
