Art-net to dmx Startup
Maby
Just started using FS
FreeStyler Version: latest
Post by Maby »
Hello,
I love the little program Art-net to dmx. It is a life saviour!
However, it has stopped working for me. Since today when I want to start the program it immediately crashes! For a few seconds the window opens as here:
Then it closes and that's it. It is not running in the background. It has worked the day before! :( The only thing I did was restarted my laptop in between sessions. There were no Windows updates in the meantime, I checked.
What I already did to solve it:
Unplugged all USB cables
I restarted my laptop (win11)
I checked for Windows updates.
I reinstalled the freestyle software (first I removed the old software).
Disabled firewall.
I did CMD > sfc /scannow
Tried to install older versions 3.5.6 and 3.5.7
> Do you know any other thing I can try?
> Do you know any similar software I could use? I run an Enttec DMX USB PRO (So USB in, dmx out)
> Do I need / How can I fully completely remove the software for a reinstall?
Maby
Re: Art-net to dmx Startup
Post by Maby »
Hi All,
An update on the things in tired - no success so far.
I found the crossing in Windows logbook as a generic "Application error 1000". (see image below).
What I tried to fix it:
https://www.minitool.com/news/event-id-1000.html
Ran additional anti-virus (again)
Clean Boot (no thirty-party programs)
Run in Compatibility Mode
System file check through sfc /scannow (again)
CMD > DISM /Online /Cleanup-Image /RestoreHealth
> Can anyone confirm the program uses .NET Framework?
Maby
Post by Maby »
I discovered in the wiki Art-Net to DMX uses .NET3.5
https://www.freestylersupport.com/wiki/ ... ersion_357
Therefore I tried to Reinstall the latest version and/or install version 3.5 of the .NET framework.
I followed:
https://www.autodesk.com/support/techni ... ework.html
First 1 ran
https://www.microsoft.com/en-us/downloa ... x?id=30135
Then I uninstall everything starting with Microsoft .NET. There were two options according to 'Control Panel\Programs\Programs and Features'. I uninstall both.
Try to reinstall the latest 4.8 version
https://dotnet.microsoft.com/en-us/down ... -installer
Got an error: .NET Framework 4.8 or a later update is already installed on this computer."
Then try to install 3.5
https://dotnet.microsoft.com/en-us/down ... /net35-sp1
But the installer won't open, even in admin mode.
Then I uninstalled all I got from 'Microsoft Visual C++ 2xxxx' on my PC. (Thinking it has some connection to .NET).
Rebooted my PC
Try to install 3.5 then 4.8 > same issue with .NET
corentink
FreeStyler Version: 4.1.6
Post by corentink »
Hola! I have the same problem, did you find a fix or a workaround?
asboyd
FreeStyler Version: 3.6.49
Post by asboyd »
I also have the same issue. It looks like the app does not work with windows 11 for some reason. I will try the same version of freestyler / art-net to dmx on my windows 10 laptop and check whether it works.
Cheers,
asboyd
Post by asboyd »
OK have tried windows 10 and the app works as it should.
Looks like this is a Windows 11 issue...
Cheers,
