Yidoblo Ai 5000 c
Qtmbth
Yidoblo Ai 5000 c
Post by Qtmbth »
Hello all,
I'm new to Freetyler and this forum.
I have this led rbgw panel from Alibaba and I can't figure out how to make that file to allow more control of colors.
I have the dmx chart attached but can anyone tell me if this light is actually able to allow individual RGB control?
And if so can anyone help me build that file?
Thanks and be well.
Best regards,
Qb
FreeStyler Version: 4.1.7
Re: Yidoblo Ai 5000 c
Post by Rod_Horning »
Can you either provide a link to the user manual or else include it as a file attachment to this thread?
From the chart you did include it looks like the instrument can be controlled via DMX but it is not clear.
Qtmbth
Post by Qtmbth »
Hello,
Thanks for your reply!
Do you want the whole manual or just the dmx part?
Thanks!
Kevin
Qtmbth
Post by Qtmbth »
Whoops hire resolution
It is difficult to read the page but, if I understand it correctly, there is a setting that will cause the instrument to react to programming from a DMX console or lighting software (such as Freestyler).
Qtmbth
Post by Qtmbth »
How about this..
https://imgur.com/a/u1rQJ6H
Correct me if I'm wrong, one has to build a fixture but it's super hard.
I'm using these to do an experimental photographic process.
Even setting the lights at 2800 Kelvin, it's just to cool and I'd rather control RGB channels to get the color I'm after.
Can anyone help?
Pic of example diy polaroid...
I've requested a PDF of the user manual from the manufacturer.
Qtmbth
Post by Qtmbth »
Thanks!
The manual literally has no useful information
I'll scan today also
Thanks again!
Qtmbth
Post by Qtmbth »
Yidoblo ai 3000_5000c.pdf
Here is for the ai3000c, as I have that light also and the instructions were the same I believe
Thanks so much!!!!!
Qtmbth
Post by Qtmbth »
Hey Rod, did the company reply?
Maybe if you have any questions I can ask the company's representative on Alibaba directly.
Thanks again :) 😊
Rod_Horning wrote: 05 May 2023, 22:12 I've requested a PDF of the user manual from the manufacturer.
If the manual is crap use a generic fixture and use the sliders on the right hand side, then you can adjust things and work out what does what and or work in combination with the manual to discover what they mean
Qtmbth
Post by Qtmbth »
Hello, could you recommend a fixture to try and a suggested start address?
Thanks so much
Be well
