First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
The Purpose of the below fixtures are so that you can in an instant add them to freestyler to get control over any lights you have that dont have profiles for them yet or if you'd like to create a fixture profile but dont have a manual to hand.
To use them download the correct fixture to your computer (you can usually find out on the case or the manufacturers website how many channels your light uses).
Double click them once on your computer then this will add them under the manufacturer 'TEST FIXTURES' inside FreeStyler
DMX Address your light to the same as you have set when adding the test fixture
Now you can select teh fixture and use the sliders window on the right of your FreeStyler screen
A Note : If your new to creating fixtures this will help you understand using the Fixture Creator and learning what values you'll need to add to Fixture Creator to build a profile
More Fixtures Added Soon!
