setup:setup_menu
Setup Menu
The FreeStyler Setup menu can be found under “Setup”.
Under this menu the following can be found and set.
Add/Remove fixtures
FreeStyler Setup
Interface Setup
If FreeStyler is used for Demo without interface or 3D view then “Virtual Interface” can be used.
As an “Advanced” setting the refreshrate of the output can be set. This determine how often the fixtures are updated.
A lower value will give a higher speed.
Note: Some fixture can, if they have a reset via DMX, be overloaded with data and thereby make a reset. So don’t run with higher speed than necessary.
TIP: 3D view and the DMX device can also run at the same time
Reset
This sets all DMX values on the output to 0. This can be helpful if something comes out of control and a start from the basic is needed. Alternative FreeStyler can be restarted.
The Supported interfaces can be found here. supported dmx interfaces
External Control setup external control
Preferences setup_menu_preferences
Use global colors
Dark theme
Dark theme changes the background color in the panels from white to a dark gray.
setup/setup_menu.1548311961.txt.gz · Last modified: by Jan_K
