Setup Menu
The freestyler Setup menu can be found under “Setup”.
Under this menu the following can be found and set.
Interface Setup
If FreeStyler is used for Demo without interface or 3D view then the “Virtual Interface” are to be used.
As an “Advanced” setting the refreshrate of the output can be set. This determine how offend the fixtures are updated.
A lower value will give a higher speed.
Note: Some fixture can, if they have a reset via DMX, be overloaded with data and thereby make a reset. So don’t run with higher speed than necessary.
Reset
This sets all DMX values on the output to 0. This can be helpful if something comes out of control and a start from the basic is needed. Alternative FreeStyler can be restarted.
The Supported interfaces can be found here. supported dmx interfaces
External Control setup external control
Preferences setup_menu_preferences
