Google Play
Apple IOS
In addition to the apps on your mobile device you need a midi bridge and a Layout editor. These can be downloaded from the download page on the website of the developer. Also detailed information on how to install can be found there.
Installation
Once all these steps have been completed it is time to startup the TouchOSC system. Find the TouchOSC Bridge program and start it. For your convenience you can let it start up automatically under windows by putting it in the startup folder in the startmenu. The bridge is lightweight and doesn't use a lot of resources.
Then we need to configure FreeStyler to allow midi input and output from TouchOSC. You can do this by opening FreeStyler. Go to Setup –> FreeStyler Setup. In the setup screen click External Control –> Midi Control. You will see the following screen:
In the left hand top corner select TouchOSC Bridge (it will only be visible when the bridge is running). Then click start.
On your mobile device you can start up TouchOSC. The Settings screen will come up. For us the main option is MIDI Bridge.
When you tap it you see Host. There you can fill in the IP address of your computer. When you have Bonjour installed you will see your computer. Then it is easy, just tap your computer and IP address will be filled in automatically. If not you will need to fill in your IP address manually. See below screenshot.
Once done you will go back to the Settings page. There you can select Layout. Just select the Keys layout for now as this is only for testing purposes. Once selected tap Done and you will get in the main screen of TouchOSC.
Go back to the FreeStyler Setup and open External Control –> Midi. On the left in the bottom there is a field which is blank. When you touch a key on the keyboard in your mobile device there should show up a value as seen in below screenshot.
Once this works you are now ready to start working on a Layout which serves your purpose or see if you can find a good readymade one in the forum. So we will go on now with creating a layout.
Click here to learn how to create Faders.
Click here to learn how to create Buttons.
Click here to learn how to create Multi X/Y control.
All the other input fields work basically the same way. Just remember that you cannot use the same channel twice with the same value.
Happy designing.
Feel free to add to the manual or correct my typos.
