Gobo keeps rotating continuously in FreeStyler with my 13ch moving head fixture — how to stop it
UrsaMaior
FreeStyler Version: 4.7.1
Post by UrsaMaior »
Hi everyone,
I created a fixture for my 13-channel moving head in FreeStyler using Fixture Creator. The fixture loads fine, but I have a problem: the gobo wheel is continuously rotating and I can’t seem to stop it. On my DMX controller, I can control the gobo rotation perfectly — I can shake it, stop it, and select gobos without issues.
I have set the gobo channel to 13 and the gobo rotation channel to 5 (Vector Speed) as per the manual. I also defined the rotation range from 0 (stop) to 255 (max speed). Despite this, in FreeStyler the gobo keeps spinning constantly.
Could someone please advise:
How should I properly configure the gobo rotation channel in Fixture Creator?
Is there something special I need to set in FreeStyler to be able to stop the gobo rotation?
What common mistakes might cause this continuous rotation issue?
Thanks in advance for your help! :fs:
FreeStyler Version: 4.1.7
Re: Gobo keeps rotating continuously in FreeStyler with my 13ch moving head fixture — how to stop it
Post by Rod_Horning »
Bring up the OUTPUT window and locate the fixture with which you are having the issue. Once issue manifests note the DMX values for the 2 channels. Are they what you expect?
Please post your fixture and a link or PDF of the manual.
Dumb question but when you use your DMX Controller is the GOBO controlled by channels 13 and 5 (relative) on the DMX Controller?
UrsaMaior
Post by UrsaMaior »
hanks for Your advice!
I have two identical moving heads. On one of them, when controlled by the DMX controller, I can change the gobo patterns and shake them using channel 13. However, on the other lamp, the gobo pattern is continuously looping and I can't stop it (even on DMX controller).
Maybe I changed something in the lamp’s settings and now it’s impossible to stop the gobo rotation?
I’m even afraid to connect the lamp that works correctly to the FreeStyler again, because I don’t want to mess up its settings...
https://imgur.com/a8T3tQu
CREATOR : https://imgur.com/cudU20T
https://imgur.com/1SKsh8P
manual user :
channel //value // functions
1 // 000-255 // pan
2 // 000-255 // pan fine
3 // 000-255 // tilt
4 //000-255 // tilt fine
5 //000-255// vector speed (normal-slow)
6 // dimmer/strobe
000-007 //closed
008-134 //100-0%
135- 239 // strobe (slow-fast)
240-255 // open
7 // 000-255 // red 0-100%
8 // 000-255// green 0-100%
9 //000-255// blue 0-100%
color macros
10 // 000-007 // no fuction
008-021 // white
022 - 034 //red
036-049 // green
050-063 // blue
064-077 // cyan
078-091 //magenta
092-105 // yellow
106-119 //purple
120-133 // orange
134-147 //chartreuse
148-161 //pink
162-175 // brown
176-189 //gold
190-203 // crimson
204-217 // violet
218-231 //crape
232-255 // color-change macro1
11 // 000-255 // vector speed(color)
12 // movement macros
000-007 // no fuctions
008-022 // auto program 1
023--037 //auto program 2
038-052 //auto program 3
053-067 // auto program 4
068- 082 // auto program 5
083-097 // auto program 6
098-112 // auto program 7
113- 127 //auto program 8
128-142 // sound active 1
143--157 //sound active 2
158-172 // sound active 3
173-187 // sound active 4
188-202 // sound active 5
203-217 // sound active 6
218-232 // sound active 7
233-255 // sound active 8
13 /// GOBO
0-7 // wzór 0
8-15 // wzór 1
16-23 //wzór 2
24-31 // wzór 3
32-39 // wzór 4
40-47 // wzór 5
48-55 // wzór 6
56-63 // wzór 7
64-71 // wzór 8
72-79 // wzór 9
80-94 // GOBO1 Shake
95-109 //GOBO2 Shake
110-124 // GOBO3 Shake
125-139 // GOBO4 Shake
140-154 // GOBO5 Shake
155-169 // GOBO6 Shake
170-184// GOBO7 Shake
185-199 // GOBO8 Shake
200-214 // GOBO9 Shake
215-235 // Positive rainbow effect with increasing speed
236-255 //Negative rainbow effect with increasing speed
Based on all of the instruments for which I've created Freestyler Fixtures, channel 5 (vector speed) probably controls PAN and TILT only.
Freestyler does nothing different, DMX output wise, than your controller. It simply makes programming much easier but, in the end, it just sends out values to the DMX channels.
Based on your post you have the user manual. Please either scan it to a PDF and post the PDF here. OR take legible photos of each page and post the photos here.
I'm thinking you have a hardware issue with your instrument but I want to read the user manual to see if my understanding is correct.
Regards
UrsaMaior
Post by UrsaMaior »
Hi, thank you very much for your response.
Unfortunately, I’m unable to upload the PDF here, so I’m providing a WeTransfer link instead. : https://wetransfer.com/downloads/10acb1 ... 1752509803
UrsaMaior
Post by UrsaMaior »
You were right from the very beginning, it was simply a problem with a faulty device. I connected a second lamp and everything works. I’m a bit embarrassed I didn’t think of it earlier. Nevertheless, it’s a lesson for me—I’ve learned how to write a fixture in the meantime, and I really appreciate that you answered my question and took an interest in the matter. Thanks and best regards.
Glad you found your problem. Sorry you are having trouble with your instrument.
Enjoy.
