fade in/out
gvrnmtwrng
FreeStyler Version: 4.1.7
fade in/out
Post by gvrnmtwrng »
no luck on my first post, so maybe this one is possible.
i'm setting up scenes, and can get the fade in control working, but i want no fade out and that is not an option on the sequence creator (it goes down to half a second but i'm looking for it to snap off)
is this possible?
Re: fade in/out
Post by Rod_Horning »
Yes.
While the Sequence Editor is open and you have the sequence step being edited, select the instrument and set the desired channel to SNAP. This is accomplished by clicking on the right side of the faders in the upper right corner or on the left side of the bar in the LAMP window until a yellow lightening bolt is displayed).
This causes Freestyler, when the sequence is run, to send the target DMX value immediately instead of gradually changing the value across a time interval.
