Hi all,
Would it be possible for one of you talented people to create me a profile for this fixture please, much appreciated
I have linked the manual:
https://www.manua.ls/beamz/intibar-300- ... manual?p=9
Kind regards
Daniel
BeamZ IntiBar 300
storer77101
- Just started using FS
- FreeStyler Version: 4.1.7
Re: BeamZ IntiBar 300
Hello
Can you supply the shape of GOBO 1,2 ...8 and the color of Color 1,2 ... 8
This will make the fixture definition more helpful when you program a sequece.
storer77101
Hey unfortunately I don't have that information.
OK.
Do you still need the fixture created?
If so, what version of Freestyler are you using?
The GOBO shapes and Color 1, 2 ... can be added to the fixture later.
storer77101
Hi Rod,
I do if possible, I am using version 4.1.5. Much appreciated
Kind Regards
Daniel
Kind Regards
Daniel
Attached is a fixture definition that I think will work with your instrument.
The GOBO wheel only has numbers as I did not see any graphics.
I did not see documentation on what color was color 1, color 2, etc. I set up macros to select the color instead of the color wheel since I could get number graphics for the macro picture.
Also, being time constrained at the moment, I did not define macros for the functions on channel 7 (I would have to create meaningful graphics and that will take some time).
Give it a try and let me know how it works. It can always be updated if you obtain additional information (such as what color matches the numbers in the macros).
I suggest you read the forum about the 4.1.5 issues. You may want to install 4.1.6
Beamz_IntiBar300.pff- (121.15 KiB) Downloaded 21 times
storer77101
Hi Rod,
Thank you very much, will try this out tonight. Your time is much appreciated.
Cheers
Cheers
