Hi does anyone have the fixture for this laser?
https://nl.aliexpress.com/item/10050050 ... 1642215924
Chinese 500mw laser fixture Topic is solved
jurdevries
- DJ
- FreeStyler Version: 4.1.4
- FreeStyler Version: 4.1.7
Re: Chinese 500mw laser fixture
Attached is my attempt at a fixture definition for your lighting instrument.
Please test and provide feedback.
After you select the fixture in the Freestyler workspace click Windows->All. I hope the Macros and Custom Sliders windows are useful to you.
CHINA Single head RGB scanning.pff- (47.61 KiB) Downloaded 147 times
jurdevries
- DJ
Hi thanks for making the fixture i will try it when it gets here!!Rod_Horning wrote: 16 Feb 2023, 01:13 Attached is my attempt at a fixture definition for your lighting instrument.
I didn't expect to get a response so quickly
Duroelk
Hi, has anyone managed to run this laser from Feestyler via DMX? I have two such lasers, I used the fixture from the attachment above, the laser was set according to the address given by Freestyler and nothing happened. Either this fixture is not entirely good or these Chinese lasers do not support DMX512 at all.
Lazerboy
- FreeStyler Version: 4.1.6
Thank you Rod! I have a slightly different laser, but your fixture works well enough to get it started.Rod_Horning wrote: 16 Feb 2023, 01:13 Attached is my attempt at a fixture definition for your lighting instrument.
Mine is the "RGB Laser 500MW Beam Line Scanner" or " SLP-RGB500""or Line Scanning Laser Light" by Guangzhou Aike Lighting
https://aliexpress.com/item/1005005997711420.html
@Duroelk, for me, it first also didn't do anything, but in my case that was because my new generic USB-DMX cable wasn't µDMX but something with an FTDI chip that needs to be configured as enttec.
