TRIXTER - Magic Ball 18*1
MrCandleLight
FreeStyler Version: 4.1.1
Post by MrCandleLight »
Hi, I just bought this Amazon lights https://a.co/d/6gTe7Cb and it says they work with DMX. I also bought the cable https://a.co/d/gfZZDXv and it seems to be working ok so far.
My trouble is with the Fixture Creation, I've trying to make it work all day and it just randomly works, I don't know if I programmed it wrong or the lights are just not working fine.
I'm attaching the file and my Fixture.
Hope you can help me! :fs:
LED 18_1.pff
My Fixture Creation
(26.4 KiB) Downloaded 66 times
Photo of the Manual
Photo of the Manual
Re: TRIXTER - Magic Ball 18*1
Explain exactly how they do not work
MrCandleLight
When I connect them to Freestyler, some features aren't working properly, like colors for example. When you press the blue color, they turn red, if you activate the strobe nothing happens. The only button that works properly is the blackout and the coloring fade.
