i'm new in freestyler, managed to setup and adress lights. So no problem.
I was wondering if it is possible to run freestyler on a seperate computer as the one the music is played on and still have music controlled lighths?
I thought there was a way thrue a network cable, but I can't find the article anymore?
Regards Frank
Freestyler on diffrent computer as virtual DJ
- gardevil
- FreeStyler Version: 4.1
- FreeStyler Version: 4.14
Re: Freestyler on diffrent computer as virtual DJ
Yes but you have to use a mic or loop the sound through the other computer.
(A mic is the easiest solution)
- gardevil
Tnx, figured that out to, but I was looking for another solution i.e. via network or so.
- colombo
- FreeStyler Version: 4.1.7
- gardevil
Tnx will try it.
