communication Frestyler on virtualdj two computers
colombo
Has mastered Fixture Creator
FreeStyler Version: 4.1.7
Post by colombo »
Good day
Were any of you able to set up S2L communication for PC1 virtualDJ plugin freestyler8 and for PC2 Freestyler? What to set where?
xever
Twitter: www.120db.uk
Re: communication Frestyler on virtualdj two computers
Post by xever »
I'm sorry, What are you asking?
Freestyler running on one PC and Virtual DJ running on a separate PC?
If so Virtual DJ plugin connects over tcp.ip, you need to set the IP address within the VirtualDJ plugin to point to the PC running freestyler.
use this tool to find your ip and test your firewall rules.
viewtopic.php?f=91&t=4966
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
colombo
Post by colombo »
Good day,
In order for the Freestyler and Virtual DJ connection to work (each running on a different PC), I had to do this. (win10 pro, VirtualDj Pro)
1 / Virtual DJ must be in PRO version
2 / Freestyler extension downloaded
3/ Virtual Dj on the MASTER / MASTER EFFECT tab set Freestyler, in its settings:
Enable - ON
Use Local - OFF
Set IP address - IP address of the remote computer where the Freestyler program is running
4/On the PC where VirtualDJ is running in the firewall, set the rule for sending to TCP port 3332. You can enable Domain, Private and Public networks.
5/ Port 3332 must not be blocked on the network router!!!! (I had a problem here, the router was set up to forward the port to another PC)
6/ On the PC where Freestyler is running in the firewall in the inbound rules to allow TCP port 3332 reception. You can enable Domain, Private and Public networks.
Everything should start working.
