I just created 3 fixtures. When I add each, everything works fine. I shut down the program, re-open, and now the intensity does not send DMX output (visible from output window). Running v 4.1.0.
What am I missing? Or is this a bug? I tried searching but there's a bunch of ads to weed through.
Intensity not sending to output
djmt99
- Just started using FS
- FreeStyler Version: 3.5.4
01ert
Re: Intensity not sending to output
Same here,
I have another pc running with 3.6.50 and there it seems like it is running fine, so I moved back to version 3.6.50 (copy the version from the other pc) and now there is also this bug.
Removing the fixture and re-adding it fixes the issue, but only to a certain point.
I will try to reproduce the error and write back.
I use Art-net btw.
I use Art-net btw.
01ert
Found the problem.... you have to crank up the Master intensity Next to the "GO" button.
