Controlling speed with MIDI
Zster
Post by Zster »
Hi!
Is it possible to control the speed of the lights with a fader?
I am not sure if you know what i mean but it its the horizntal bar just beneath the grid where you can see which direction the light is pointing.
Can someone help me?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Controlling speed with MIDI
Post by Mattotone »
Try setup -> freestyler setup -> external control -> Midi.
There all listed and most self explanatory look for sequence speed.
Zster
Post by Zster »
Its not sequence speed as i am not running any sequences.
I am only using the direct bezies to run my lights. There is a bar that controls the speed of those. Its that bar i would like as a fader on my MIDI control.
I hope you understand my question, im not the best at English.
daantas
Post by daantas »
setup -> freestyler setup -> external control -> Midi -> Midi to dmx
configure a midi note to the appropriate dmx fader that the speed of lighting controls
Greetz Daan
Post by Mattotone »
unfortunatly bezier speed is not currently supported via midi
