fixture file for High End Systems Intellaspot XT-1
johndezon
FreeStyler Version: 3.6.51
Post by johndezon »
fixture file for Moving Head named Intellaspot XT-1 of company High End Systems is not in the list unfortunately.
manual is on
https://www.highend.com/documentation/I ... Manual.pdf
DMX protocol is on p.42
screenshot in attach
39channels
2 gobo's , and each gobo seven lithopatterns
An intellaspot fixture has two Gobo wheels each with seven rotating lithopatterns™ and effects plus an optional lithopattern for position four on Gobo wheel 1. Each Gobo wheel uses Gobo Function and Gobo Position parameters to control the positioning and rotation of the wheels. Gobo Rotate Function and Gobo Rotate parameters control the individual aperture position and rotation on each wheel.
i tried to make a fxt file with fixture creator without gobo, see screenshot in attach, but as i don't know the difference between Focus Function (DMX 28) and Focus (DMX 29 and DMX30), it would be very nice if someone want to review it and/or give me feedback.
the Beast is totally not under control at this moment, i can't even show a green or a red light when i want...
Re: fixture file for High End Systems Intellaspot XT-1
Post by Jan_K »
Hej.
The information in the manual is not to good.
The DMX values are missing in the DMX table.
Channel 34 is a behavior of the shutter channel. For a start you don't need to set that one.
Shutter ch. and Strobe ch. are both to be 35 if I read the text bellow the DMX table correct.
But the values to enter is missing.
I think that I would try with "Open" = 255, "Closeed" = 0
And "Low" = 10, "high" = 250. These two values you may need to fit.
And you need to set "Intensity channel" to 36. no additional values.
I can not see how you strike the lamp.
And when you test the fixture you need to set the intensity as well as the open the shutter to get any light out.
johndezon
Post by johndezon »
thanks you very much Jan
if i understood it right , i made the changes and you can see it in the screenshot:
unfortunately i cannot add the fxt file
although, i do not get any light out of it (controller is ok in settings of Freestyler, and DMX is the right channel 1 on fixture) , i am missing some basic setting and/or i did not understand what you are exactly meaning with
"I can not see how you strike the lamp."
Post by Jan_K »
I mean how you turn on the bulb.
And you you can't upload fxt files only pff so you need to export the file to pff.
One way to debug the fixture can be to use the sliders in right side of FS. There you can manually operate the channels one by one and see what works and what doesn't.
johndezon
Post by johndezon »
found one error: i choosed Sunlite, but i had to choose Sunlite 2006 for my usb-to-Dmx device,
then Freestyler is reacting to pan and tilt like it should
not yet ok: light on/off , colour of light
johndezon
Post by johndezon »
intellaspot xt1.pff in attach
exported to pff tnx
sliders on right side in FS is handy , tnx for this too
pan/tilt ok
lights on/off not ok, even when testing with all sliders manually on right side
sometimes i see some light appearing for 0,5seconds, but it is uncontrolled
lamp is not broken, that's sure.
Intellaspot XT1.pff
(717 Bytes) Downloaded 21 times
johndezon
Post by johndezon »
this 'Intellaspot Luminaire DMX Control Protocol' can help to help me, and others
Intellaspot_protocol_12-9-4.pdf
how to get the light on
(94.46 KiB) Downloaded 25 times
Post by Jan_K »
If I look at the DMX table
Then 34 = 0, 35 = 255 and 36 = 255 should do the trick.
And 39 = 80 should turn on the lamp.
johndezon
Post by johndezon »
as you said,
it did the thing,
pff in attach (without gobos)
light can go on and off now, tnx !
it is not yet completely ok, it is mainly purple even when i change the sliders manually Cyan, Magenta and Yellow
Intellaspot XT1v2without gobos.pff
(729 Bytes) Downloaded 23 times
Post by Jan_K »
Okay.
You are up running.
I can see that you have a long way as this is a bit complex fixture.
There are a lot of combination possibilities in general which gives new ranges and functionality for the sliders.
Even the shutter on channel 34 and 35 change functionality.
Looking forward to see the result.
