Rainers 12W LED Par Can
hcoff5250
FreeStyler Version: 3
Post by hcoff5250 »
Hello,
I have been searching various threads on the site for the following light but I can't find one with working strobe functions and proper color matching. If someone could provide a link or download to one that would help so much! I have the manual attached along with the link to the light itself.
RAINERS Light: https://www.amazon.com/gp/product/B01N0 ... UTF8&psc=1
Manual: https://drive.google.com/file/d/1Vmpwi6 ... sp=sharing
Thank you,
Hunter
:fs:
hcoff5250
Re: Rainers 12W LED Par Can
Post by hcoff5250 »
Here is the file I've been using (as it is the same model of the light I have) and editing to try and get the strobe function to work.
Thanks!
FreeStyler Version: 4.1.7
Post by Rod_Horning »
If you have not done so try using just the standard sliders to set the channel values to obtain the strobe effect.
Please report to what you set the channel values and the observed result.
hcoff5250
Post by hcoff5250 »
Hi Rod_Horning,
Thank you for assisting. For some reason, I am getting the same results after cleaning the custom sliders and then using the default values listed from the manual. I (think) I set them properly, if not please let me know the error.
I have set the par cans themselves both on CH 16. I keep getting a blue + white wash every time I click any color on the color grid -- the only different is it get's brighter or dimmer. The macros are also not working but I believe this goes along with the first error.
Please let me know if I should edit or review something to get this working properly. Thank you!
hcoff5250
Post by hcoff5250 »
Should I remove the preset macros by chance? On the color grid with every color selected I only get a blue output but just the brightness changes.
