Dear friends,
I need your help for SONGXU SX-MH1915A - Moving Head 300W LED fixture. I didn't find anything match till now.
Here is the DMX channels manual.
Thank you.
SONGXU SX-MH1915A
gremlins4x
- FreeStyler Version: 3637
- FreeStyler Version: 4.1.7
Re: SONGXU SX-MH1915A
Attached is my attempt at a fixture definition for your instrument.
Please test and provide feedback.
Freestyler provides several helpful programming windows. Select your fixture then click on the top menu item Window and then click All. The following will be displayed:
Colors (2 tabs exist in this window - Fixed Colors and CMY-RGB)
Gobos
Lamp
Pan/Tilt
Macros
Beam
Custom Sliders
The Fixed Colors tab in the Colors window controls Channel 22
In the CMY-RGB tab note the 3 check boxes in the lower left corner. Each box controls an individual set of RGBW leds. Check 1 or more of the boxes to select the LED you want to control.
The Gobos window controls Channel 23
The Macros window controls Channel 24
Gobos
Lamp
Pan/Tilt
Macros
Beam
Custom Sliders
SONGXU_SXMH1915A_24ch.pff- (100.35 KiB) Downloaded 35 times
gremlins4x
Thank you very much. You are great.
