PROLIGHTS lumi4 RGB Fixture Topic is solved
ardena
Post by ardena »
Hello, my name is Arturo, i'm a new member of this forum and this is my first post. So my apologies in advance first for my english then for some mistake about rule of the forum that is unknow for me.
I bought on amazon a LIXADA usb-dmx interface in order to connect it with my 4 parLed kit Prolights lumi4 rgb to use it with Freestyler.
I have not found a fixture for this device, so my question is, may i use another fixture to do this, or i have to create a new one ? I'm not an DMX expert operator so there is sombody able to help me ?
Thanks in advance
(13 KiB) Not downloaded yet
FreeStyler Version: 4.1.7
Re: PROLIGHTS lumi4 RGB Fixture
Post by Rod_Horning »
Please post either an uploaded PDF of or a link to the user manual. Without that it is difficult to provide assistance.
ardena
Post by ardena »
in attachments the manual.
Thanks Rod
fari led LUMI4RGB_manuale.pdf
(672.04 KiB) Downloaded 25 times
Arturo
Attached is my attempt at a fixture definition for your instrument.
Please test and provide feedback.
The following programming windows are available for this definition:
Color
Lamp
Macros
Custom Slider (used to select Auto programs).
To control the 4 lamps I used the RGB segments feature. In the Colors window please note the 4 check boxes in the lower left hand corner. If a box (or boxes) is/are checked the corresponding lamp will respond to the color window.
The custom slider to choose the auto program is used since the manual did not specify the specific DMX channel values. If you determine the values either a Gobo window could be defined or additional macros added to select the program.
Prolights_LUMI4RGB.pff
(19.38 KiB) Downloaded 25 times
ardena
Post by ardena »
Thank you so much Rod, i'll try it as soon as possible and i will notice you.
