Searching for Mini 3x3 LED Spider Light Fixture (TomTop) Topic is solved
JAZ-Man
Post by JAZ-Man »
Hello everyone.
I have searched the Forum but unfortunately didin't find what I was looking for.
I bought a Mini 3x3 LED Spider Light from TomTop (link below)
On TomTop the name is: AC100-240V 100W 9 LEDs RGB Rotatable Stage Beam Lamp
Mini Triangle Spider Light Lighting Fixture Supported DMX512/ Sound Activated/ Auto-running/ Master-slave for Disco DJ Show KTV Bar Club Pub Home Party Decoration Feast Festival Holiday
https://www.tomtop.com/de/p-l2696eu.html
I tried to do a fixture with Freestyler for on own but didn't succeed :(
Can anyone help me with this one?
Attached you can find the manual which was inside.
Thank you so much in advance.
I would really appreciate your help!
Mini 3x3 LED Spider Light.pdf
(2.43 MiB) Downloaded 197 times
FreeStyler Version: 4.1.7
Re: Searching for Mini 3x3 LED Spider Light Fixture (TomTop)
Post by Rod_Horning »
Attached is my attempt at a fixture definition for your instrument.
The following are the helpful Freestyler programming windows available for your Mini.
Click on Windows -> All to display all of them (after you select your instrument).
Colors
Lamp
Macros
The Macros window controls channel 17, the effect channel.
The Lamp window controls both the intensity and the strobe channels.
The Colors window controls the colors of the 3 lamp sets. In order to enable use of the Freestyler color pallet each lamp is defined as an RGB segment. Which lamp or lamps are affected is controlled by the 3 vertical check boxes in the bottom left of the Colors window. If a box is checked the corresponding lamp set will respond to the color pallet.
The X and Y axis are controlled by the standard Freestyler sliders which are located in the upper right hand corner and activated when you select the instrument. The effects speed control is found in the standard sliders also. RESET can be found from the Fixture menu item.
Your feedback is very welcome.
tomTop Mini 3x3.pff
(42.04 KiB) Downloaded 191 times
shiftypants
Post by shiftypants »
Is this fixture still suported or is there a office release
If it is in here then use it:
viewtopic.php?f=23&t=4528
Otherwise download my version in this thread.
