Relay activated overide? Topic is solved
jbaker2290
Post by jbaker2290 »
I want to have my lights set running a select pattern normally, but I have a relay that closes on an external piece of equipment that I would like to activate an alternate pattern while the relay is closed. What would be the best way to interface the relay with freestyler? Thanks for the help.
FreeStyler Version: 4.01
Re: Relay activated overide?
Post by Partyman »
Really not understanding your problem. What is this relay you speak of? Is it DMX? If the device is DMX then you can make a button to activate and deactivate
jbaker2290
The equipment is not related to lighting but when the equioment is in a certain state it will turn on a 110v output that can be used to turn on say a regular lamp. I would instead like to have it turn on a relay which would then close activating an override in freestyler.
Post by Partyman »
You would either have to have a DMX dimmer/switch pack to operate the relay or the relay itself must be dmx. Freestyler is DMX lighting software that is not designed to run other products except with the above option.
FreeStyler Version: 4.1.7
Post by Rod_Horning »
jbaker2290
Partyman wrote: 11 Feb 2019, 01:21 You would either have to have a DMX dimmer/switch pack to operate the relay or the relay itself must be dmx. Freestyler is DMX lighting software that is not designed to run other products except with the above option.
Im not trying to control a relay with freestyler, im trying to activate a scene in freestyles using a relay from another machine. I want the machine to control the program
Post by Partyman »
If the machine has midi output then you can set it up to control freestyler
Some usb dongles accept DMX in but won't do both at the same time so with two boxes if your relay sends out a dmx signal it can control FreeStyler which will then send out dmx from the other box!
