Limiting pan and tilt movements? Topic is solved
Timebomb
Post by Timebomb »
Hello,
First post hear so first off respect to the developers for a wicked peice of software.
Im makeing a fixture and trying to limit the range for pan tilt but i cant see how to do it. I would like to limit the pan and tilt range of the pan/tilt tool to 0-167, as beond 167 there are pre programed cycleing pan and tilt movements.
Does anyone here know how to do this?
Many thanks
ames
daantas
Re: Limiting pan and tilt movements?
Post by daantas »
You can pan and tilt limit change in your scene
Ga to Setup> Freestyler setup> Preferences> Pan / Tilt resize
Here you can pan and tilt limit change
Greeting Daan
ceretz
Post by ceretz »
thats right, but if i have five moving head and only two are "particular"(with a resized pan\tilt movement)how i can do it?
thx :fs:
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Unfortunately due to the rarity of this problem freestyler is unable to support this mode of operation.
Kind regards
Matt
ceretz
Post by ceretz »
thanks martin,
i posted becouse i have similar problem, becouse i have five Led moving heads with a 450°pan and not 360° and i have a problem to program figure for automatic movements.
There is a solution with modifiing the fixture file with notepad?? thx for yor time
Timebomb
Post by Timebomb »
Thanks people, i think im going to make some bottons for the preset pan and tilt movements and make do with that.
One more question if i may?
I have 8 roboscans, but for most gigs i will only use 4. I would like to program for the 4, and when i take all 8 out have them running the same sequences as the first 4, but with inverted pan. I see there is an invert pan function, but is there a way to link the first 4 units with the other 4 units, so i dont have to program everthing twice?
The scanners i have dont have an invert pan function, wich is a shame as i could just run them on the same dmx channels, is there any way to do it with freestyler or any other software, that will copy dmx channels 1-48 to channels 49-96, but with inverted pan.
Thanks again
James
4 on xx address and 4 on another address program them all the same by highlighting all eight fixtures then go back over the 4 you want to use invert and change program accordingly if you have 8 all set up but only want the 4 to work blank the 4 you dont want by selecting them and overidding them to blackout... or create make a single sequence tp blackout the four and put it on an overide button then you can map to a key on keyboard and walla! 4 on 4 off or 8 on 0 off
daantas
Post by daantas »
In the new releas comes a "disable fixture from playback" funktion and a "diable fixture output" funtion
greetz Daan
Post by Mattotone »
I must of missed this feature, what current version of fs u on?
daantas
Post by daantas »
2.99b im testing that version nou
Dblab
Just started using FS
FreeStyler Version: 4.1.6
Post by Dblab »
Hello,
Same problem here in 2023. No way to specify (s2l random) pan/tilt limitations for each groups separately.
Moreover, a little update of the "fixture creator channel description" wiki could be usefull.
Dblab
Post by Dblab »
Up
Please explain more about the wiki you wanted improving like the specific page,
With regards to your main issue request it on the bug tracker which also acts as a feature request system
Dblab
Post by Dblab »
For sure.
https://www.freestylersupport.com/wiki/ ... escription
This is not to date.
I probed for my part, without finding solution to the problems listed above, but the "wiki" is not to date.
I tried check/uncheck the "enable" square near the group list without noticing any change
