I hope someone can help me.
I started to make a fixture file for my Ayra TDC Burst 6 fixture and first filled the easy channels (colors). Now i'm trying to add the rotation and color mixation but i have no clue where to place these things.
Is there someone who can finish my file or give more explanation how to do this ?
Thanks in advance !
Ayra TDC Burst 6 help needed Topic is solved
Fkl8
Ayra TDC Burst 6.pff- (3.33 KiB) Downloaded 25 times
IMG_20170820_0001.pdf- (660.69 KiB) Downloaded 21 times
- FreeStyler Version: Beta
Re: Ayra TDC Burst 6 help needed
Hej.
Looking into the data sheet then there is no description of what color mixation does.
This means you first need to figure out what this channel does.
If you use the slider in right side of FreeStyler for channel 6 and change the value slowly then each time you see a change then you record it.
When you have figured out what this channel does the you can decide how to add it.
Think I would try to place it on the color wheel.
Channel 7 motor: Think the easy way to add this will be to use the gobo wheel and then add some icons which represent the functionality.
And Ch8: two macros on / off.
