Need a fixture for the laserworld el-230rgb.
Tnx en greatings richard
Laserworld el-230rgb
Sliquid
Nathanrs93
- FreeStyler Version: None
Re: Laserworld el-230rgb
That picture is no good to us. We can't read anything from it, so I'd suggest finding the manual online and posting a link to it instead. Then we should be able to help.
- FreeStyler Version: Beta
Test
It looks like the forum still reduces resolution on images uploaded.
That may be the reason for the poor image.
Here is a link to the manual.
https://www.laserworld.com/en/support/d ... 16-09.html
- FreeStyler Version: 4.1.7
Attached is my attempt at a fixture definition.
Please test it.
Feedback appreciated.
After you select the instrument in Freestyler click on Window -> All (top menu item).
You should see the following windows open( you may need to move them around in order to see all of them):
Beam
Lamp
Pan/Tilt
Custom Sliders
Please test it.
Beam
Lamp
Pan/Tilt
Custom Sliders
