Error Message - Open Failed Topic is solved
discoadz
Post by discoadz »
Hi guys
I seem to get the error message "open failed" everytime I open Freestyler - even though it doesnt seem to open, and work fine.
Any ideas?!?
thanks
Ad
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Error Message - Open Failed
Post by Mattotone »
Windows has its own driver for the open even thou it can work, its not recognised by freetyler uninstall the hardware and reinstall the correct driver from enntec then plug the device back in.
Matt
discoadz
Post by discoadz »
Hi matt
Thanks for the reply. I'm not using Entec, Im using a JMS USB2DMX.
Adam
is that compatable with FS? you may have the driver installed wrong somehow... try re-installing it....
discoadz
Post by discoadz »
Hi matt
Yeah, its in the list of controllers, and I've used it fine on another PC.#
I've unistalled and reinstalled freestyler, but still get the same message "Open Failed!" on open.
As far as i can see - the software works fine -but its not very comforting!
any ideas?
thanks
Adam
there could be numerous problems, drivers not installed properly, faulty device, freestyers problem etc etc send that to here to try to determin if it its a bug [bugreporting][/bugreporting]
