Hi, does anyone know of a way to assign a hotkey to RGB values to increase or decrease by a certain increment each time it is pressed?
For example, if I have a 6 channel LED parcan (R,G,B,Macro,Shutter,Dimmer), can i assign hotkeys so that a press of "1" will increase R value by 10 or something. Likewise, "2" and "3" would be to increase G and B values, and "a", "b", and "c" to decrease each.
Many thanks
Christopher
RGB hotkeys
- FreeStyler Version: x2
- FreeStyler Version: 4.01
Re: RGB hotkeys
You can do it with keyboard shortcuts but I believe you have to use CMY instead of RGB. Do a search for how to program keyboard shortcuts
Re: RGB hotkeys
Let's start with the manual - where is it?
- FreeStyler Version: Beta
