Fixture for SHOWTEC Led Clubscanner 20W Topic is solved
setoyyy
Post by setoyyy »
I am looking for settings for SHOWTEC Led Clubscanner 20w . I have attached the user manual.
Any help would be appreciated!
LED-Clubscanner-20W-Manual.pdf
(1.92 MiB) Downloaded 31 times
FreeStyler Version: 4.1.7
Re: Fixture for SHOWTEC Led Clubscanner 20W
Post by Rod_Horning »
The manual is confusing. In one place it states the fixture uses 12 DMX channels. However, in the section that documents DMX channel usage it only lists 5 channels.
setoyyy
Post by setoyyy »
I Don't know but everywhere on the internet are these Features:
5 Channel Compact DMX LED scanner
Sound active, Master slave, and DMX mode
14 Gobo's 11 Colors
20 Watt white LED
Ideal for mobile DJ's and small venues
Weight: 4,52 kg
Dimensions: 410 x 270 x 140 mm (LxWxH)
Focus: Manual
Gobo's: 15 fixed gobo's
Colors: 12, 2 multi, white
Power connector: Schuko
This "12 chanels" is probably a writing error
