Multi Colored Buttons?
DJDaveSA
FreeStyler Version: 3.6
Post by DJDaveSA »
Hi all. I am trying to map a Numark Orbit to control cuelists and blackout and smoke. I can programe the buttons fine and the jog wheel works great for the master intensity.
My question is? Is there a way to change the color of the buttons so they are always lit in a certain color and then have them respond by changing color to whatever cuelist is active?
If it is not currently possible, I will put in a feature request.
David
the_pproject
FreeStyler Version: X2
Re: Multi Colored Buttons?
Post by the_pproject »
I think its not possible. You can change the button - color in the Orbit Editor, but FS "reset" the color and it´s always white. (My experiences!)
Greets
Boone
FreeStyler Version: 2.96g
Post by Boone »
Also for me works great but also colour is always black or white. Please can this be changed?
FreeStyler Version: 4.01
Post by Partyman »
You change the colors in the Freestyler midi setup area using numbers in the on/off columns. You will have to experiment to get the exact colors you want.
pesga
FreeStyler Version: 3.5.1
Post by pesga »
Maschine jam, vía hardware
