I have lots of lights in something I am currently doing and when I click to create a new chase, every single attribute on every fixture (from par can to martin mac) gets selected as "snap" and turns yellow to match. This means that I can't run multiple cues. For example.
Let say I have 8 parcans 1 - 4 and 5 - 8.
I record a chase on 1 - 4 and by default 5 - 8 are set to snap. (With no value as in the light is off). I then record a chase on 5 - 8 and by default 1 - 4 are set to snap with no values. However I can't run both chases together. Because when I run the 1 -4 chase it sets 5 - 8 to snap to 0, and then when I try and add in the 5 - 8 chase it will snap the lights in the 1 - 4 chase to off.
In this production I can't just go round turning every value off because I have about 100 lights and it would take too long.
Hope that makes sense.
Tom
Chase Topic is solved
- FreeStyler Version: 4.01
Re: Chase
At the bottom of the sequence creator box there is an option for static or transparent. You are currently using static, recreate your scenes using the transparent mode.
Rusty
Rusty
