Futurelight EYE-19 RGBW
Hardcoreman
Basic 16 bit mode (20 ch). Tested.
Futurelight_EYE-19_RGBW.pff- (11.34 KiB) Downloaded 154 times
- FreeStyler Version: Beta
Re: Futurelight EYE-19 RGBW
I get an error when I try to open your pff.
Value out of range. It may be that
What version of Fixture creator are you using.
Can you please try to save if again and import it again to see that it works.
(remember to make a back-up of the original fxt file before playing around with the files.)
Hardcoreman
Thank You! Everything is OK, BUT after export, something changes the values. I use Fixture Creator 6.8. I don't understand why happened this. Now I upload the original photo and fxt file.
RGBW-packed.zip- (4.95 KiB) Downloaded 142 times
Hej
I have looked on the zip file fixture.
Some of the COT images are missing in the zip version so it is not usable for others.
And I have been debugging on the pff file.
It looks like Fixture creator don't like the two lines in Channel description where you have "," in.
I have not tried to se if it is the "," or an other illegal char which has been used so I have just tried to delete description on channel 6 and channel 20.
When I do this then it is possible to export and import the fixture correct.
I will add this to issue to the bug tracker.
