Custom command programming Topic is solved
soundsinvision
Post by soundsinvision »
I am trying to set a button so that it runs a sequence of instructions. One is going to be:
- stop submaster 1
- stop submaster 2
- stop submaster 3
- set a range of DMX Channels (say 80-93) to be value 0
So they will run from one button (I'm working with an LJ who is used to a Masterpiece and is looking for as similar experience as possible).
Is there a way of stacking commands (as listed in the external commands list in the wiki) up to run from one key trigger?
FreeStyler Version: 4.01
Re: Custom command programming
Post by Partyman »
It can be done but not the way you are thinking. You would have to make a cue that affects all the fixtures you are trying to control. If submaster 1 controls par cans then your cue would tell the par cans to turn off. Cues cannot be made to control submaster, sequences or Override Buttons, only fixtures.
