Hello,
my problem is the smal cout of stepps in chases.
i want bild somthing with 8 LED Stipes with 3 colors. by using steps to light up one afer an other with the 3 colors the 45 Steps are not enough.
is it posiple to add chases in a line? to create something with more than 1 chases to create al list chase 1 than chase than chase 3 an so on.
Kind regards
Sequenses and chases Topic is solved
- FreeStyler Version: Beta
Re: Sequenses and chases
Yes you can edit that in the ini file.
Have a look in the Sequence section
http://www.freestylersupport.com/wiki/f ... leshooting
