Problem with Master Intensity
Apricotemanuele
FreeStyler Version: 3.7
Post by Apricotemanuele »
I have six identical machine in my Freestyler. All of these fixture have been imported from the same file. When the lamp is open and master intensity go from 100% to 0 all the lamp are turned off except one. The problem is solved by changing the channel of the machine with the still open lamp, but if you restart the program the problem returns with another random fixture. Have you any idea?
spud1511
FreeStyler Version: 3.5.7
Re: Problem with Master Intensity
Post by spud1511 »
If you set your 6th fixture to the same DMX address as the 5th fixture, then you can troubleshoot by checking that it properly mirrors the 5th one next to it as you test run through the different functions.
If it behaves properly and copies the 5th fixture then this tells you there is likely just an addressing issue, like the address on fixture not being the correct one.
Otherwise, different behaviour would likely be a menu setting on the fixture itself, like how many channels / which 'mode' the fixture is set to.
Chuckf082351
Post by Chuckf082351 »
I am having a problem getting the Master Intensity to work with any of my fixtures. These are fixtures I created using the Fixture Creator. I am guessing this is a problem with configuration. Does anyone have ideas on what to check?
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Check your fixture configuration. Is the Intensity channel coded with the correct channel?
