hi all,
i need your help, i have led 24x12w zoom moving wash, i already create the fixture, all work correctly only few i do not know how to fix, like when i hit button "blackout on" it still "alive", second problem when at strobe, i hit button open, the speed for pan/tilt going slow, third problem, the fixed colors not work correctly..
hope anyone can help me which part that is wrong..
here i attach picture for the fixture and picture for the user manual
need help to make correction on fixture
- FreeStyler Version: 3.5.8
- Twitter: https://twitter.com/kelik_1994
- FreeStyler Version: Beta
Re: need help to make correction on fixture
I had a look on your pictures.
I noticed that you have channel 14 "Pan Tilt Speed" on shutter. Remove that.
Strobe channel in the off field set that to 0.
That should clear some of your errors.
hi Jan_K
Thank you so much, because some of errors are fixed..
Hej again
If you have a working fixture then remember to upload it to the forum.
