acme butterfly Topic is solved
dr_rog
acme butterfly
Post by dr_rog »
Hi I have a generic Chinese one of these and wondering if anyone has done the fixture profile for 12 or 36 ch DMX? I searched but unable to find it?
I am just starting out with DMX control, and struggling with more complex fixtures!
acme butterfly.pdf
(2.52 MiB) Downloaded 48 times
dr_rog
Re: acme butterfly
Post by dr_rog »
Please note pdf manual now attached.
Any help appreciated
kittmaster
Commited FS Forum helper
FreeStyler Version: 3.6.2
Re: acme butterfly
Post by kittmaster »
There are not enough fields to properly handle this fixture in 36 channel mode, will contact dev to see if we can sort something out.
Re: acme butterfly
Post by Jan_K »
Try this one.
Tilt1 and tilt2 are placed on gobo 1 and 2.
I know that it is not a movement channal but on the other hand it don't make sense to use pan - tilt as you can't use any of the shapes and so on.
If you wan't to make movement then you can use the "Fx" function on gobo1 and gobo2.
ACME_Butterfly_36ch.pff
(38.01 KiB) Downloaded 29 times
