I have a sequence with 2 scanners (jb systems winner).
And i have a sequence with 8 pars (ADJ megapar profiles)
When i play the par-sequence in a cue, the scanners are off, like it should be.
When i start the scanner-sequence in the cue, the scanners switch on, but the pars keep on shining, they do not switch off.
(Multicue is off)
What are possible the causes?
How can i solve this?
Thank you
stompinne
- buttza
- FreeStyler Version: 3.6.4
Re: How can i solve this?
Are your Pars running in 3 Channel RGB Mode?
If so you will need to add an RGB off step in your Scanner Sequence. Scanner On / RGB 0% = Red 0%, Green 0%, Blue 0%.
