Laser Excelighting club 500 RGB Topic is solved
omsoad
Post by omsoad »
Hi i'm new on this forum.
I'm a french Dj and i'm starting animation activity.
I start using Freestyler with my lights and I have just buy this Laser but it's too difficult for me to create fixture in fixture creator.
Is anyone able to help me or create a fixture for me?
I will upload what i have try to do but it's a very bad creation. I continue to edit the fixture...
omsoad
Re: Laser Excelighting club 500 RGB
Post by omsoad »
Just a world: too difficult for me. 24 Ch is to hard...
No one can help me?
Post by Jan_K »
Hej omsoad
Lasers are in general a bit difficult as nothing fit into the normal control.
I just had a look for a manual and the only one I could find was a French and that don't make it easier.
But a start will be to attach a manual here then we can see if anyone will give it a try.
Post by Jan_K »
Hej again.
I had a brain accident so I copied the French DMX table into a word doc and used google translate.
Can you have a look on the text and eventually correct what google missed in the translation.
That could be a start.
Also you said 24 channels.
The DMX table have 26 ?
Excel_DMX_Chanal.docx
(52.01 KiB) Downloaded 54 times
Post by Jan_K »
I had a closer look on the table and I think you should make 2 fixtures, one for each beam, and then use them as combined fixtures.
Placed on the same start address.
See eventually the tutorials on the wiki.
I think I would split them this way.
There are a lot of patterns where you have to figure out how they are configured.
My guess is that they are controlled by channel 4/15 and channel 26 in combination.
You probably don't the images for the patterns so give them a number icon.
There is also a laser tutorial on the wiki.
omsoad
Post by omsoad »
First thanks for your answer.
I have read your translated document. I think it's good. There is some grammatical errors but all is easy to understand.
There is 26 channels, not 24, sorry.
I had a look to your fixture proposition... Does it mean that i will use the laser as two separated lasers? Only one fixture seem to be impossible?
I think that i will create (if possible) a simply fixture with minimal controls: i will do only beam show for the moment and will not use drawing.
i will start to create your "double fixture" and post it here, and maybe also try to create another fixture just for beam show in automatic sound mode...
I will read tutorial for that!
Thanks again, and see you later.
ps: sorry for may bad english!
Post by Jan_K »
Hej again
Sorry for the late answer. (Vacation).
I think you will get the best performance if you split this in two fixtures.
Else I think you will end with a lot of faders which you don't have any feeling with.
There are some tutorials of how to use combined fixtures.
http://www.freestylersupport.com/wiki/f ... d_fixtures
http://www.freestylersupport.com/wiki/f ... ter_effect
There is also a lase tutorial but lasers are in general a bit difficult to control.
http://www.freestylersupport.com/wiki/f ... ld_rs_200g
