I have been using 3.5.5 for a month with everything stable, untill tonight....
With Freestyler open I was rearranging some sequences which probably caused Freestyler to crash.
I tried to relaunch Freestyler but with no result so I rebooted and tried it again, with no results.
The Freestyler logo appears but nothing happens and after some seconds the logo disappears and nothing happens. No error messages. Nothing.
I removed the software and did a new install. I tried this 5 times already but Freestyler does not want to run anymore on my laptop. There is just the logo and then nothing....
Does anyone have a clue what is the cause?
Freestyler not launching anymore Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: Freestyler not launching anymore
i have no idea..
but if you reinstall FS you also need to Remove all the register keys on Windows otherwise a Reinstall doesnt work as the old info is still on the pc...
you can also try to open the Freestyer.ini file with a Notepad and change RESET = FALSE to RESET = TRUE save the notepad and restart FS... this way it will startup as Factory default...
- FreeStyler Version: Beta
http://www.freestylersupport.com/wiki/f ... leshooting
Here is a guide of how to delete the registration.
