Moving heads to do opposite movements
Djwesty
Post by Djwesty »
Hi
Need some help guys,
Running to pr 150 lights dmx in a pair. Want them to do the same thing apart from the pan so they cross over each other!? Please help I'm new to this so be gentle!
Cheers
Nathanrs93
FreeStyler Version: None
Re: Moving heads to do opposite movements
Post by Nathanrs93 »
Invert pan on one fixture either in the software or on the fixture it's self. I'd personally do it in the software then you can always sell the fixtures at a later date and know nothing has been changed (which you'd have to tell the buyer or change them back if you did)
Djwesty
Post by Djwesty »
Brilliant cheers , think change pan in program sounds better, where do I go to change the pan on one light?
I'm a real novice help is needed!
Thanks again
Nathanrs93
Djwesty wrote:Brilliant cheers , think change pan in program sounds better, where do I go to change the pan on one light?
Thanks again
It's alright. If you go on the software and then click the icon which looks like a grid icon on the bar at the top, it will open the pan and tilt window (select the fixture before you want to invert). Then you should see X and Y buttons near the top right hand corner, click them and one will invert the pan, one the tilt. :)
Djwesty
Post by Djwesty »
Sorted it ! Brilliant thanks for the info major help !! Cheers
