Help with Chauvet Intimidator profile
djmt99
Just started using FS
FreeStyler Version: 3.5.4
Post by djmt99 »
I'm awaiting the delivery of a few Chauvet Intimidator Beam LED 350 fixtures. I built my own profile, but since there isn't a fixture in Easy View, I decided to play around with a Intimidator Spot 350 instead. I notice 2 things right away:
1) It only Tilts 90-degrees (+/- 45-degrees of center) and Pans 180-degrees. I know the fixture can pan 540-degrees and tilt 270-degrees. Is that possibly related to my second issue, which is:
2) I had mentioned this in another thread, but when I select anything other than a figure 8 (ie: circle, rectangle), the patten seems to follow the pattern twice, similar to the figure 8. I sort of understand the explanation of rescaling, etc (viewtopic.php?f=6&t=1594#p22700), however I'd like to see a screen shot of someone's bezier or pan/tilt grid that is moving an Intimidator MH to help me better understand.
Thanks for the assistance.
djmt99
Re: Help with Chauvet Intimidator profile
Post by djmt99 »
This is the file I've been playing with. I've left the Pan/Tilt Range field empty, at 255, and at 540/270, all yielding the same behavior as mentioned above.
Chauvet_Intimidator_LED_350.pff
(96.04 KiB) Downloaded 72 times
