easy view not displaying gobo or colours
I'm running freestyler on Vista. When using easyview, the roboscans do not show any change in gobo shape or colour. They respond to movements though. Any suggestions ?
Re: easy view not displaying gobo or colours
Ok, I've even tried a single Martin 812 setup with just one head positioned in easy3d and still no colours or gobo changes. I need a solution to this since I've got 3 shows coming up !
- djSupport
i havent a clue but then again i do not use Easyview 3d at all so I hope someone else is able to help you!
To clarify, I'm using the visualiser within freestyler. Magic 3d easyview. What visualiser do you use if your not using Easyview.?
- djSupport
I Just Don't LOL! and yes FS easyview i just don't USE it lol My FS use is unique to probably anyone on this forum.... so I only need to use bits and peices
Just asking !
. I've just upgraded to a Tablet Thinkpad but its running on Vista so I can't use Lightjockey to Visualise my chases anymore. Its a weird problem, I'm not entirely covinced that its not an issue with Vista, since it was running just fine on my other laptop with XP. Any advice would be appreciated since I've got a show in 48hours time.
- djSupport
erm visualise them in your head? .... Are all the DMX address set ok in Easy? are they exactly set the same as FS? trouble shoot go over things again....
I thought it might be an address issue, so I set up a single roboscan unit and tried that. Still no luck though.I'll keep trying !
- djSupport
open fixture creator and also the easyview equivelent and check to make sure they both correspond with the same DMX values
Well, after spending a while on this today, I've now got Lightjockeys visualiser working on Vista ! So everything appears to be OK at the moment. I still haven't resolved the issue with it though. I guess I'll have to leave it. Thanks for the advise though.
- djSupport
no worrys and gud luck!
