JMS USB2DMX Interface Problems
LordAJ
Post by LordAJ »
Hi
I recently bought the JMS USB2DMX interface. It is in the supported interface list for the beta. And have tried it but it doesnt work. It somtimes comes up with "Open Failed" but it otherwise seems working. It works with other software. It only seems to work on the software that you have to click "DMX Connect" or "connect". Is there a connect button in freestyler somwhere? do you have any solutions to this problem?
Thanks in advance :)
Re: JMS USB2DMX Interface Problems
please send that issue using this form :
[bugreporting][/bugreporting]
Thanks,
LordAJ
Post by LordAJ »
ok, will do :)
dekw1
FreeStyler Version: 3.5
I Use FreeStyler for: None of your damn business!
Post by dekw1 »
Try entering your "JMS" unit as "enttec open dmx" This works for my "JMS" interface.
Cheers Dek. :idea:
Un gel spГ©cial est utilisГ© pour aider si vous avez vasculaire cГ©rГ©bral et de crise cardiaque.
let us know how u get on...
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Post by matt »
also, make sure the drives are installed correctly for the usb adapter.
Here is a tip.
Close all open programs, Freestyler, Word, IE, FF, Etc..
Make sure there are no Modem or COM Port Inspection programs open.
Plug in DMX adapter.
Wait till you hear the DuDE Sound..
Go to Device manager, (right click my computer, click properties, click hardware, click device manager)
Make sure your dmx adapter is listed with no ! or X by it.
Start FreeStyler.
Matt Hankosky
flickr.com/photos/mattxhank
LordAJ
Post by LordAJ »
ok, well ive done what you guys say:
Enter it as an entec open. And checking out device manager. But still nothing. No response at all :( And it works with other programs but none of them are as good as Freestyler. Any thing else that could solve this problem?
LordAJ
Post by LordAJ »
Success, im getting somthing. Its what i want its just a few mins after i have issued the command :(. Could it be the refresh rate? How can i change this in free styler?
Return to “DMX Interfaces”
