Hi guys n girls, im having trouble with what i think is my ENTtec open DMX interface, the problem is this - i use Freestyler 3.5.2 with an ENTtec open DMX interface, attached to this i have 5 SGM VII 250's, 2 Highend Trackspots and 1 QTXlight par64, this set-up works fine. i purchased a Martin Magnum 1800 smoke machine and added it to the DMX chain at the correct address, the dmx signal led on the Magnum doesnt light up and freestyler has no control over it whatsoever, i borrowed a visual dmx interface and downloaded the program, wallah - it works perfect, i am set in my mind that freestyler is the software i want to continue to use but really need the smoker to through dmx control.
I used fixture creator to create the Magnum fixture, on opening the program i selected, fogger/hazer.
once opened i entered the manufacturer, model, selected a picture, total channels as 1, fog/level channel as 1, fog/level min as 0, max as 250. on the channel description page, description as intensity, locate as 250 and default as 0.
ive been using freestyler for about a year now, i installed and linked all the fixtures together, set there dmx addresses and created the sequences/chases etc, so i have a knowledge of the basics at each step but cant figure out the problem i am faced with.
Any help would be gratefully appreciated.
Gary
No smoke with entec
- FreeStyler Version: 3.5.2
- Spirit
- FreeStyler Version: 3.5.9
Re: No smoke with entec
hi this is no Enttec issue..
as its just the DMX protocal and its realy straite forward.
but you can look if you REALY addresed the Fixture correct.
also look very carefull how the dip works on some fixture''s DIP up = OFF and othertimes its ON same with DIP down = OFF and othertime ON..
and you can look is a Fase twist works..
SO Normal
PIN1 = Ground/VDD
Pin2 = COLD -
PIN3 = HOT +
but it can be inverted
PIN1 = Ground/VDD
Pin2 = HOT +
PIN3 = COLD -
SO Normal
PIN1 = Ground/VDD
Pin2 = COLD -
PIN3 = HOT +
PIN1 = Ground/VDD
Pin2 = HOT +
PIN3 = COLD -
- FreeStyler Version: Beta
I just had a quick look on the Magnum 1800.
It is a normal pinout.
So the error is some were else.
Connect the fogger and the Enttec direct with a cable you know is working.
Start FreeStyler and see that the DMX signal led is on.
If not then try connectiong an other fixture and see that the DMX signal led on that one is on.
This way you know that the Enttec works.
Place evt. the test fixture after the magnun so you can see that the dmx signal passes through the magnun correct.
