Lanta fireball LED par64S
UK-Sub
Post by UK-Sub »
my first attempt as a newbie creating a fixture file for the Lanta Fireball Par64s unit. can be configured in 3,4, or 6 channel DMX mode. There may me more features to add or improve this fixture creation but it appears to serve well as it is here.
Fireball Par64 LED.zip
Lanta Fireball Par64s LED RGB par can
(1.12 KiB) Downloaded 29 times
Re: Lanta fireball LED par64S
Post by Jan_K »
Please use the export function in Fixture Creator and upload the pff files.
They contain all data to the fixtures. ;)
Is it this one then here is an image that can be used.
UK-Sub
Post by UK-Sub »
apologies. complete newbie here. hopefully this one is suitable
Fireball Par64 6ch.pff
Lanta fireball 64s
(25.61 KiB) Downloaded 28 times
Post by Jan_K »
Jeps This is the right way.
Some small comments.
In the comment box it says that this is a EuroLite, 5 ch mode, by Plasma.
Think you should correct that. ;)
And it looks like you lost the 3 and 4 channel fixture somewhere.
Else it looks nice.
I can see that it is a fixture that shift function on channel 2 depending on the channel 6 settings.
You can add them in the macro tab. I can see that there are many functions and there are some errors in the DMX table so it is a large task to do.
UK-Sub
Post by UK-Sub »
thanks for the advice.
like i said, total newbie. new to all this stuff only in the last few weeks.
I'll do my best to update and hopefully send something back that is better.
thanks for your help and patience
Post by Jan_K »
Well you allready have 10 bonus points in my little book because you have tried to create a fixture.
A lot of otheres just request a fixture without trying. :D
Will be glad to help / guide you.
UK-Sub
Post by UK-Sub »
Here's my latest attempt.
Not sure if it is possible to combine the 3 operating modes of this unit within one fixture package.
That'll be learning for another day.
comments or approval welcome.
thanks
Fireball Par64s 3ch.pff
Lanta fireball LED par64S 3 channel DMX mode
(17.4 KiB) Downloaded 29 times
Fireball Par64s 6ch.pff
Lanta fireball LED par64S 6 channel DMX mode
(25.59 KiB) Downloaded 27 times
Fireball Par64s 4ch.pff
Lanta fireball LED par64S 4 channel DMX mode
(17.47 KiB) Downloaded 29 times
UK-Sub
Post by UK-Sub »
also noticed that putting speech marks " in the comment section of fixture creation corrupts the file when saving. Found this out the hard way!
Post by Jan_K »
Something like this?
