Looking for fixture Spot-LED 30w Moving head Topic is solved
keithsplace
Post by keithsplace »
I have two moving head fixtures that I am not sure what they are. They are fairly new.
No name on them, all I can tell you is the following.
They are made made in China, Sticker on top says Spot-LED 30watt.
In the menu of fixture, they have 8 or 12 Channel mode selected selection.
They look a little like a ADJ Q-spot more like Neptune Midi Spot 30 mod.J81785
Anyone have an Idea what they are, or can post ficture channel values?
I need the DMX values to build the fixture unless someone knows what this fisture is.
Here is link to pictures of the fixture.
http://www.performancepluspc.com/spotled_30w.htm
JamesLS
FreeStyler Version: 3.5.2
Twitter: https://twitter.com/#!/JamesLS
Re: Looking for fixture Spot-LED 30w Moving head
Post by JamesLS »
Is there a manual for them?
Without a manual or make/model not much I can do.
keithsplace
Well that is the problem, there is no brand on them. I think I just about have the channels and values worked out and just about have the profile finished. Not exactly correct or exact with the Gobo images and colors but pretty close and I think I can use it as is for now, till I find and answer as to what all these things are, adding all the rotations and moving gobo's are the worst. But I have the colors, gobos, pan,tilt, gobo rotation moving working so far.
I'll post the fixture profile when I get it to a good working profile. I also notice one oddity with the two of them. Addressed them both the same and when through each funtion to make sure the values would work with both, the second color is not the same on both, the acctual color wheel doesn't have the same color gel
in it. So I would guess I need to fix that for them to be really right, I am sure I can use them and work around that for now.
keithsplace
Posted manual for fixture Spot-LED 30w Moving head
Finally found the manual for the Mini Spot 30w Moving head.
I have the 12 channel model, it will also run in 8 Channel mode, according to the menu selection
in the fixture.
I will encluded the manual for the 11 Channel version as well.
If someone that is versed in building a fixture, please post.
Like I said I build one but it is not complete or exact as it should be.
30W white 11ch MINI SPOT MOVING HEAD.pdf
30W white 11ch Mini Spot Moving Head
(161.91 KiB) Downloaded 145 times
30W white 12ch MINI SPOT MOVING HEAD.pdf
(185.43 KiB) Downloaded 147 times
kristoffer
Post by kristoffer »
Here is a fixture for the 8 channel version. When you import it it's gonna go in under manufacturer "IMPORT".
Minispot 30W (8 ch).pff
Ver 1.0 (Not tested)
(102.96 KiB) Downloaded 161 times
