Hi Guys
I have so far managed to figure out the software without asking too many questions. I have 4 ADJ Mega Par profiles and using the fixture for the ADJ Flat Par Tri which works fine. I have created some sequences which work fine when playing them within the editor. When I add them to cues, the first one I play works ok but if I press play on a second one, the colours are not what was set in the sequence editor. It's like it keeps the colours there from the first cue I played ruining the 2nd one?
Any ideas?
Possible noob question.
- Twitter: http://www.twitter.com/shane_cup
- Spirit
- FreeStyler Version: 3.5.9
Re: Possible noob question.
hi look at this link i think this is your problem.
http://www.freestylersupport.com/wiki/c ... d_tutorial
But this goes about the Submasters but how to program a Sequence stays the same.
if it sill doesnt work or you dont understand it just ask again.
Cheers! Sorted out the colour problem. That link helped.
Only thing left to concur now is when pressing a cue after a strobe effect, it strobe for the first second or so.
- Spirit
uhmm can you axplain this a little nit more because i dont understand it.
Basically if I go from a strobe effect on cue to a fade. It will still strobe at the beginning of the new cue/scene
